October 3, 2023, 17:05 |
2 inlets 1 outlet blood mix
Cheng Peng
Hi everyone, I'm new to Fluent and have some questions. When I try to mix two blood flows in a Y-shape tube, they do not mix. Instead, their streamlines are parallel and do not cross to form vortices. I only used laminar model and set the boundary conditions two "velocity inlet" and one "pressure outlet". But even I set the inlet1 as 0 velocity, there is still no any flow through it. Is this because of the "velocity inlet" boundary conditions? Can anyone help me about this problem?
My goal is to use the blood from inlet2 to "push" the blood from inlet1 back(see the figure). |
November 27, 2023, 15:57 |
Sebi
Rep Power: 7 |
What goes in, must come out. Inlet 2 cannot push flow back out of inlet 1. It can slow it down, but everything that comes in through inlet one, must leave through the outlet to conserve mass.
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
natural convection in square cavity having inlet and outlet | sujeet | OpenFOAM Running, Solving & CFD | 1 | November 2, 2019 02:17 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Two inlets! One air and one mix of gases | Dary | FLUENT | 11 | February 17, 2013 22:40 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
