October 14, 2023, 04:19 |
Density on fluent doesn't work
Hello guys,
So basically I'm doing a project to simulate horizontal wind turbine, I got the input variable from the experimental experiment. I'm doing the simulation with rotating frame method and my inputs are angular velocity, velocity, and density. The experimental result I got 0,01 and the simulation result I got 0,92 torque which the gap is huge and I suspect it's because of the density of my blade count as default, and I think this is the reason. So my question is, how do I applied custom density on my blade? I tried to edit the density on set up materials in ansys fluent and spaceclaim even I tried both and it still doesn't work. How do I solve this, my density really small which 28,1821 kg/m^3 and the blade's mass only 2,5 because I made it only from wood as a structure and some kind of paper for the cover. These are my mesh quality, inputs, and torque. |
Getting density, temperature, and other cell flow variables via macros in Fluent UDF | ingabobjoe | Fluent UDF and Scheme Programming | 2 | August 15, 2020 21:08 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Fluent does not work | MASOUD | FLUENT | 4 | April 9, 2012 13:23 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent does not work on openSUSE 11.0 | Stanislav Sviderek | FLUENT | 1 | July 28, 2008 17:21 |
