December 25, 2022, 10:37 |
Multiphase and DPM
Ayushman
Rep Power: 4 |
I have a particle mass loading of 10%.
How could I use this value in ANSYS Fluent? |
December 26, 2022, 06:58 |
Alain Islas
Rep Power: 6 |
In Fluent, the volume fraction (particles volume / flow volume) is result of your DPM setup. After setting your DPM injection, particle size, mass flow rate, etc... and running 1 FTT (at least). You can count the particles within your system and evaluate yourself the volume fraction. In other words, you dont specify this value a priori.
Also, for DPM to work properly, the cell size should be larger than the particle size. |
October 29, 2023, 10:11 |
Ayushman
Rep Power: 4 |
I performed a 2D simulation of the shock wave in shock tube using shock capturing method. Now I want to plot a graph of x-t (x co ordinate vs. time) for the shock wave in the shock tube. It was a unsteady with turbulent model, simulation using the Ansys Fluent. So, is there any way that I can plot x-t graph for the shock wave using the Ansys Post-Processing??
Thank You. |
Confused between DPM and multiphase flow | pchoopanya | FLUENT | 0 | June 21, 2019 04:44 |
Multiphase Flow Fails after DPM Injections | salmanayon | Fluent Multiphase | 1 | November 10, 2016 10:53 |
Scaling down Fluent Model - Multiphase Flow and DPM Injections | salmanayon | Fluent Multiphase | 0 | October 13, 2016 00:29 |
DPM and Multiphase models | attaullah | Fluent Multiphase | 1 | September 15, 2016 14:08 |
DPM or MultiPhase - Criteria - Help | jpinho | FLUENT | 2 | January 18, 2010 11:55 |
