November 5, 2023, 07:06 |
Diverging Results with density based solver
Ashwin
Rep Power: 2 |
Hello all, The inlet of my geometry has a supersonic nozzle. I am trying to simulate flow through it in steady state initially and then later in unsteady conditions.
With the density based solver I was able to get a decent steady state solution altho the residuals weren't perfect(oscillating somewhere between 1e-3 and 1e-4). When I started to run the transient solution , my results start diverging near the wall, which I think is caused by high accept ratio cells near the wall/inflation layers. Without the inflation layers, it is not diverging. However, when I use the pressure based solver I am able to get really good results with inflation layers as well. I want to recreate the results using density based solver as Mach number in my flow downstream exceeds 3. Please let me know how to fix this issue. I will attach pictures I have also tried turning warped face gradient correction off but it still diverges in the transient simualtion. Courant no - 5 1.So how do I reduce residuals in steady state, right now its oscialllting somewhere between 1e-3 and 1e-4 2. How do I prevent this from diverging as shown above in transient sim? Thanks |
November 5, 2023, 22:03 |
Ashwin
Rep Power: 2 |
Hello guys, any help would be greatly appreciated, Thanks
On the Roe approximate Riemann solver in the preconditioned density based method | sbaffini | Main CFD Forum | 22 | March 19, 2022 11:20 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Floating Point Error when using density based solver | sa64r | Main CFD Forum | 0 | February 10, 2021 10:54 |
Pressure based and Density based Solver | Xobile | Main CFD Forum | 39 | August 19, 2020 06:04 |
Density based solver with cnst density! | p_agoodboy | FLUENT | 0 | November 8, 2010 22:18 |
