December 20, 2023, 02:37 |
Porous zone direction
Rep Power: 4 |
I have several thin plates with holes in it. I want to model them with porous zones. I know the resistance factor from formulas. The issue is that I cannot allign all plates with a coordinate axis (x, y or z). So for instance if have calculated a resistance of 10 for the plate. If the plate makes an angle of 45 degrees with the x and y axis. Should I use for the axis direction a value of10xcos45 and for y 10xsin45? And for the z direction an infinity value, because this is in the plane of the plate? Hope you can help me out. |
direction vector in porous media | arash.mp | FLUENT | 0 | April 1, 2019 10:06 |
Degassing B.C. and porous zone | C.C | FLUENT | 0 | December 18, 2018 07:24 |
buoyantBoussinesqSimpleFoam with porous zone (source term) problem | cissystef | OpenFOAM Running, Solving & CFD | 0 | May 26, 2015 08:05 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
define porous zone in fluid domain | pannsave | FLUENT | 0 | March 24, 2014 07:27 |
