Why do residuals oscillate after set no. of iterations? |
January 25, 2024, 05:10 |
Rep Power: 2 |
Hi guys,
I'm modelling a heat transfer with a DO radiation model. After a number of converging iterations the residuals start to oscillate (as in the image attached). Can anyone explain why this could be/ if this is an issue or not. Thanks! |
January 25, 2024, 06:34 |
Moritz Kuhn
Rep Power: 17 |
One possible explanation is that your flow regime is not fully stationary. Turbulent flows are partly random, so normaly this is not an issue, if mass and energy balance is ok.
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
