April 15, 2024, 05:53 |
Helppp!! Conjugate Heat Transfer Problem
Dennis Ho
Hi everyone, im a student doing my final year project, which involved investigating how different types of material and wind speed impact conjugate heat transfer. i was tasked to run a experiment which uses a open looped wind tunnel with a heating plate, i would then use ANSYS Fluent and compared the results.
The experimental's heating plate (0.127 x 0.127 m) has a 240 VAC, 450 Watt which has heat flux of around 27900 W/m2 and also includes a safety feature when it reach 150 degree c, the heat flux cuts off. In the simulation, i have used transient with 600 time steps where i only analysis the results up to when the temperature have reached 150 degree c. however comparing with the experimental set up, the results are off, one possibility i have notice from the contour plots is no conduction in the solid domain and i dont understand why is it like that. is it because of my settings? Please help me. experiment.jpg 3 ms, Inlet 297 K, 1.8A, 600 Steps.png |
April 16, 2024, 16:46 |
Kareem
Rep Power: 3 |
How are you applying the heat flux? Which solids are you not seeing conduction? I only see one solid in the picture
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
Convergence in a conjugate heat transfer problem | Mohamed Abdulazim | FLUENT | 5 | March 28, 2020 16:41 |
fluent conjugate heat transfer problem | eling | FLUENT | 9 | October 21, 2017 11:10 |
Transient conjugate heat transfer problem | troyker | FLUENT | 0 | June 21, 2013 04:37 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 16:41 |
Conjugate heat transfer problem | Soheyl | FLUENT | 2 | March 15, 2008 15:15 |
