absorption and scattering der particle
Old   March 6, 2000, 10:59
Default absorption and scattering der particle
tang xin
Hi,all. I simulate off-gas(containing particls) combustion with DO model for radiation. I'd like to consider the effect of particls on the absorption coefficent and scattering coefficient. First I have not included the effect of the particles and got a convergence solution. Then I open Model->Discrete phase Model, turn on the particle Radiation Interaction option, set injection surface and got a convergence solution too. However, when I check the surface average veolicity,temperature,specis concentration at outflow surface, these two situatuins are not different. Then I have checked the absorption coefficient. It is the same for the two situations,too. I hope someone to give me a clue.
Thank you in advance.
Tang Xin
Absorption & Scattering Co-efficients, Radiation mp Main CFD Forum 15 May 18, 2020 22:39
Can't set absorption coefficient for inert particle lauripar FLUENT 1 May 9, 2012 15:09
absorption and scattering coefficient value kvimalraj Main CFD Forum 0 March 23, 2011 02:44
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
need absorption and scattering coefficients. Pablo FLUENT 1 May 16, 2007 15:50
