Unsteady Background Job ?
Old   June 19, 2000, 12:55
Default Unsteady Background Job ?
Prateep Chatterjee
I have been running Fluent jobs in the background (batch). The input file I have used has the form:
rc x.cas (reading the case file)
rd x.dat (reading the data file)
it 1000 (1000 iterations)
wd x1.dat (writing data)
etc.
This input file was for steady state cases. I'm trying to run unsteady cases now. Do I need to make any changes to the input file ? I don't see any indication of an unsteady case running, though the case has unsteady solver specifications and a time step setting. I need to run the jobs in the background and can't run them interactively (nice value is higher for interactive jobs on the SGI machine I run the cases).
Old   July 13, 2000, 13:57
Default Re: Unsteady Background Job ?
lizheng
You should add another step to run unsteady in the backgroud.
For example, add solve/set/
solve/dt/ in your input file.
Good luck,
Lizheng
Running unsteady problems in the background Jie Cui FLUENT 0 February 17, 2005 17:59
How to start background job ? Piet Siemens 7 August 21, 2004 04:35
parallel background job using v3.20 star-user Siemens 0 July 28, 2004 12:37
How do I send a job to the background in Unix Ammu FLUENT 2 July 19, 2004 17:00
Input file for Background job Prateep Chatterjee FLUENT 0 June 10, 2000 17:59
