surface-creation on 1 of 2 overlapping fluid zones
Old   November 17, 2000, 05:15
Default surface-creation on 1 of 2 overlapping fluid zones
Volker Pawlik
Hello Fluent community,
due to simplifications i.e. shortening of pipes of a domain to save cells I now have an overlapping grid.
Imagine three pipes connected by two 180° turns which leads to that the third pipe is parallel to the first. At the end of the third pipe is a box whose dimensions are bigger than the pipe field. Due to the fact that the last pipe is shorter than the others the box, the first, and the second pipe are overlapping.
It is no problem for the solver but for postprocessing: Creating a surface always cuts both zones (pipes and box). For surfaces on which only velocity vectors shall be displayed it is possible to bound it to the acoording interior-zone. But displaying a filled contour-plot on such a surface just gives a contour coloured grid
Does anyone know a trick how to tell fluent to create the surface only for one of the two overlapping zones?
Thanks in advance
Volker
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
Free surface VOF (fluid render effect) franco STAR-CD 1 July 20, 2009 05:42
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
