pressure drop
Old   February 1, 2001, 10:13
Default pressure drop
atholl
Hi folks, I'm modelling the flow of water through a pipe and was wondering if there is any provision for calculating the pressure drop along the pipe in Fluent? (is it somewhere in the 'report' menu?) I've done the calculations on paper and want to compare my results with Fluent. Any answers would be appreciated.
Old   February 2, 2001, 01:52
Default Re: pressure drop
Jin-Wook LEE
Report --> Surface Integral
Options : Area(or Mass-Average)
Field Variables : Pressure (Static, Dynamic or Total as for your purpose)
Sincerely, Jinwook
Old   February 2, 2001, 15:43
Biblo
You could create specific points along a line and find out the value of pressure at those points. Use that to calculate dp/dx.
From pull down menu
SURFACE --> POINT (create points)
Then,
PLOT --> XY PLOT ( choose write to file option)
This will write pressure at specific points you selected in the domain into a file.
Let me know if you able to match the calculations on paper. I was off by a good 20%. Also I couldn't get mesh independent results.
Good Luck !
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
