March 11, 2001, 22:51 |
UDF for wall heat flux ?
Hi ! Fluent users
I am tring to use UDF to modificate the heat flux at the wall boundary. However, I can't find the Fluent's variable which denotes the wall heat flux in the function " DEFINE_HEAT_FLUX". Is there anybody who know this variable name? please let me know. Thanks in advance. |
April 13, 2001, 16:49 |
Re: UDF for wall heat flux ?
Looks like you may want to use DEFINE_PROFILE instead of DEFINE_HEAT_FLUX. DEFINE_PROFILE allows you to define a heat flux profile while DEFINE_HEAT_FLUX allows you to define the way to calculate heat flux. In other words, if you want to specify heat flux as a function of location, DEFINE_PROFILE is what you need.
June 9, 2001, 10:58 |
"Looks like you may want to use DEFINE_PROFILE instead of DEFINE_HEAT_FLUX. DEFINE_PROFILE allows you to define a heat flux profile while DEFINE_HEAT_FLUX allows you to define the way to calculate heat flux.In other words, if you want to specify heat flux as a function of location, DEFINE_PROFILE is what you need."
Hi, I have a similar problem: I want to specify a heat transfer coeficients profile around a turbine blade in 3d. Ok, my profile is constant all over the blade span. To have an exemple of what FLUENT expects as an input file. I ran a dummy case, then PROFILE-> Write, I choose my surface and Heat transfer coefficient and now I have a file with: 4 vectors (x, y, z, heat transfer coefficients). I have a huge amount of points (all the nodes of my mesh I guess...), but I just want to specify a few points. Is there a mean of doing that or have I really to specify a value for each nodes??? |
June 14, 2001, 00:22 |
My understanding is that
DEFINE_PROFILE allows you to define the heat flux profile at the surface whereas DEFINE_HEAT_FLUX allows you to define the heat transfer co-efficient profile at the surface I have used both in my codes. You can specify a constant or variable values depending upon how you write your udf. Do this by accessing the node, face data and adjacent cell data at the surface. Example: If you want to modify just some points for a different heat transfer co-efficient you can use the example for DEFINE_HEAT_FLUX in the udf manual and add a test to change h at a particular region on the surface. Greg |
December 3, 2014, 13:17 |
#5 | |
Farzad Montazery
Rep Power: 11 |
I am writing UDF code for variable heat flux over a circular tube but H value is unacceptable, could you please look at my UDF and tell me my mistakes? #include "udf.h" DEFINE_PROFILE(axial_flux_profile,t,i) { real x[ND_ND]; /* this will hold the position vector */ real q; real m; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); q = 0.5; /* q is the heat flux at z=0 in W/m2 */ m = 1; F_PROFILE(f,t,i) = q*exp(0.5*m*x[3]); } end_f_loop(f,t) } Best Regards Farzad |
September 15, 2016, 11:14 |
hussein
Rep Power: 9 |
please help
how can i define the heat flux as a function of temperature of wall q=1000*(1-0.014*(T-298)) any one can help me in writing the UDF please |
August 4, 2018, 05:44 |
#7 | |
CFX - wall heat flux | divarano | CFX | 2 | December 4, 2006 16:14 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
heat flux to heat rejection | azmir | Siemens | 0 | June 23, 2004 20:53 |
UDF for a heat flux applied during T second on a w | nazeem | FLUENT | 0 | June 12, 2004 10:28 |
udf for transient heat flux BC | isaac | FLUENT | 1 | June 3, 2004 16:29 |
