S.O.S:A problem about meshing.
Old   April 16, 2001, 09:25
Default S.O.S:A problem about meshing.
qiuwuyu
Hi, I am calculating velocity and press field of flow in heat exchanger now. The shell-and-plate heat exchanger was column with helical baffle.But I can not mesh the volume by using gambit ! I am use fluent juet now . Please tell me what should I do? Give me your hand! Thank you ! (My email:qiuwuyu@263.net )
Old   April 23, 2001, 04:16
Default Re: S.O.S:A problem about meshing.
Harry Qiu
Hi, Two points: (a)See the error message printed by the gambit in the left-lowest of the screen. (b)reduce the mesh spacing(or space)to one smaller value(it's default value is 1). hope to help you. Harry.
Old   April 23, 2001, 06:01
qiuwuyu
Thank you for your help! The error message is :
Assertion failed in Fcae PrepTool.cc, line336:test_valence>=min_valence while meshing valume 94.
But I don't know what does it mean?Can you tell me!
Thanks!
Old   April 23, 2001, 07:36
Harry Qiu
sorry,I don't know what it means too. But check the volume 94 meshing in detail. Another point is that you should specify the zone boundary type only after you meshes the entity.
Sincerely, Harry.
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
Meshing problem Sanjay Jain FLUENT 6 April 5, 2008 09:51
