How can I determine which viscosity / specific-heat model was used from CAS file? |
April 6, 2018, 12:37 |
Daniel Norton
Rep Power: 11 |
I am trying to determine which model was used to model properties in some recovered data files. We've used some custom materials, and they have multiple inputs for specific heat and viscosity. For example, the viscosity is shown as (formatted for clarity): (viscosity (constant . 3.79e-06) (sutherland 1.716e-03 273.11 110.56) (power-law 1.716e-05 273.11 0.666) ) In this case, is the viscosity modeled as a constant or using the Sutherland Law or Power Law? I can't load the files directly in Fluent as the computer we used is dead. Thanks for your help! |
April 6, 2018, 13:59 |
Lucky
Rep Power: 66 |
The first stuff that appears in ( ) is the setting used. So in this case it was a constant viscosity of 3.79e-06. The other hint is: the coefficients for Sutherland and power law are still the defaults.
April 7, 2018, 15:07 |
Daniel Norton
Rep Power: 11 |
Great, thank-you very much!
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
