Volume grid growth
Old   July 10, 2001, 09:00
Default Volume grid growth
Troy
Apart from insuring a point in the laminar sublayer. How far(inches) should a volume grid be grown from the surface, using the spacing normal to a solid surface required to yield 1 grid point in the laminar sublayer?
Old   July 12, 2001, 14:38
Default Re: Volume grid growth
Lanre
The volume grid should be grown according to the Reynolds number of your problem. To compute the BL thickness or y+, estimate this from correlations in any Fluid Mechanics textbook.
The typical spacing recommendations to reduce diffusion errors is a 20-30% growth rate, i.e., normal length of cell from wall should not increase by more than 30% from the preceding cell. Put about 10 cells in the BL.
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
[Commercial meshers] CuBit t42 OpenFOAM Meshing & Mesh Conversion 6 July 10, 2008 07:51
Finite Volume Approach For Unstructured grid APURVA SHUKLA Main CFD Forum 2 March 15, 2001 00:14
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
