September 12, 2001, 01:35 |
WARNING:multiple shadows
hi,
I am trying to simulate the flow past rotor/stator configuration in compressor.When I import the mesh file into fluent it gives a warning that some face threads has multiple shadows. can someone tell what may be the possible reason for this warning and also the remedy for it. thanks and regards, suneesh |
September 12, 2001, 10:26 |
Re: WARNING:multiple shadows
as far as I remember the warning can be forgotten.
September 12, 2001, 12:19 |
How to remove it? My Fluent version is 5.4.8
September 13, 2001, 05:21 |
I meant: ignore the warning!
Or is it impossible for you to start the solver? As I already mentioned: I had had the warning sometime in the past. All what I remember is: The warning had no influence on solving the case. If it is different in your case, contact your fluent office or try it with fluent 5.5. |
September 13, 2001, 11:07 |
In Fluent 5.5 it is working without problem
September 16, 2001, 10:10 |
In Fluent 5.5 also I can't make the interface periodic. If I try it is showing BUS ERROR suneesh
September 30, 2001, 04:06 |
Hi Suneesh,
I also experienced such warning messages with my FLUENT 5.1, but in an electronic New Feature Documentation the following procedure is proposed: grid -> modify-zones->repair-duplicate-shadows This warning appears,I thing, when your planar zones, which you want to be periodic, are composed of several faces with common nodes, so that at least one node belongs to several faces. I use another procedure in such case: in GAMBIT I define another, but distinct types of boundary conditions on the zones which I want to be periodic, and after reading the mesh I use text commands grid->modify-zones->make-periodic Of course, you must have as identical mesh on both zones as possible (some differences are tolerable). I hope this could help. Petr |
Bezier-Bernstein approximation for airfoil shape | DoHander | Main CFD Forum | 10 | April 23, 2014 06:21 |
wall shadow | rage | ANSYS Meshing & Geometry | 1 | August 15, 2010 17:36 |
Wall Shadows | Naghman Khan | FLUENT | 4 | July 20, 2007 13:43 |
multiple shadows | Nurul Murad | FLUENT | 1 | September 28, 2001 10:35 |
