Flow-Response Dynamic Coupled problem
Old   September 21, 2001, 13:57
Default Flow-Response Dynamic Coupled problem
wavefront
I have to perform a flow simulation, after I finished the flow simulation and get the pressure distribution in the analysis space, I'd like to put the pressure on a part which is in the analysis space, to see how dose the part vibrate under that pressure.
Anybody could recommend a software to finish this task? Currently, I'm using FLUENT because there's some turbulence in the analysis space, but FLUENT can't do vibration analysis. It's a kind of Flow-Response Dynamic Coupled problem.
Thanks a lot
Old   September 26, 2001, 12:48
Default Re: Flow-Response Dynamic Coupled problem
Lanre
Take a look at these examples on the web:
http://www.fluent.com/about/news/new...98v7i2/a17.htm
http://www.fluent.com/about/news/new...01v10i1/a9.htm
Old   September 28, 2001, 11:33
wavefront
Thanks Lanre,
That gives me some clues.
Thanks again
Segregated or Coupled flow? hamzamotiwala STAR-CCM+ 7 October 25, 2011 19:35
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Simulate flow field of moving body by dynamic meshes luckyluke OpenFOAM Running, Solving & CFD 5 January 10, 2006 04:37
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
