How to import STL ?
Old   September 26, 2001, 00:08
Default How to import STL ?
Liao
Can fluent support STL file ? and how to import ? thanx
Old   September 26, 2001, 12:10
Default Re: How to import STL ?
Lanre
You can import an STL file into GAMBIT. The resulting geometry is not real but faceted and thus you will be unable to perform Boolean operations. This may or may not be an issue depending on the state of your STL model.
Remesh the faces (may need lots of clean up to merge itty-bitty faces into larger ones), and then the volumes, export your mesh to FLUENT.
Old   September 27, 2001, 04:51
Liao
Thanks for response.The STL imported is not a real geometry.I try to import STL as a mesh File,then the nodes and faces can be identified.But there are no volumes found.Should I import STL as a CAD or mesh file?
Old   September 27, 2001, 08:43
Karl
You should import the STL as a mesh file. There are no volumes because a STL-File has only a faceted surface mesh consisting of triangles.
Tip: Try to decrease the feature angle for better resolution of all details in the geometry
ICEM CFD: Import STL file error 8leemichael ANSYS Meshing & Geometry 4 October 22, 2015 22:46
import STL got problem fathan FLOW-3D 2 March 10, 2010 17:29
[GAMBIT] STL file import into Gambit Ibo ANSYS Meshing & Geometry 4 May 18, 2009 00:58
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
STL file import to GAMBIT Spyros Stamatelos FLUENT 3 January 11, 2007 12:20
