October 4, 2001, 05:57 |
Hershel-Bulkley viscosity
Can anyone tell me how to go about modifying the non-Newtonian Power-Law viscosity in Fluent to include a true yield stress, which would make it a Herschel Bulkley viscosity? I know this would be via a UDF, but is there any way I can get access to the existing code for Power-Law viscosity and then modify it as a UDF? Or do I have to start a UDF from scratch myself, and if so, how? Thanks in advance
October 4, 2001, 10:06 |
Re: Hershel-Bulkley viscosity
Hi Atholl,
I have been working for a long time in the area of viscoplastic fluids and have already experienced to include this kind of models (Bingham or Helschel-Bulkley) in Fluent. Concerning that point, I have two news for you : a good one and a bad one 1. good new : implementing visoplastic fluids in Fluent works very well !! and besides is very easy to handle. You only have to write an UDF for the viscosity. 2. bad new : for confidentiality reasons (I am currently working for a private company), I cannot forward you the UDF. Nevertheless, I encourage you to try too because you are now absolutely sure that it will work (if you trust me of course). And I can show you how to consider the model in Fluent because obviously, after a deep look in the literature, you would probably find it by yourself, so I expect that the following tips will enable you to save some time. Consider the Bingham constitutive equation in 3D (the generalization to HB model is straightforward) : tau=2*mu*D+(2*D/gamma)*tau_0 tau=stress tensor mu=shear viscosity D=rate-of-strain tensor gamma=(second invariant of D)=sqrt(2*tr(D**2)) tau_0=yield stress If you write this relation in terms of apparent viscosity mu_a, it yields : mu_a=mu+tau_0/gamma An other thing to keep in mind is that the relation tau=f(D) or tau=f(gamma) in 1D (in that case, gamma is the shear rate) is discontinuous in gamma=0 and tau cannot be evaluated (for gamma=0, tau in [0,tau_0]). A popular solution consists in using any of the following regularization models : 1. bi-viscosity model 2. exponential model 3. model with a parameter epsilon I chose to use the exponential model which can be written as : mu_a=mu+(1-exp(-m*gamma))*tau_0/gamma with m=numerical parameter If m is great enough (typical values verify m>100), the regularized law fits well the real consitutive equation. Thus, your regularized law exhibit now good properties : continuous (stress can be computed everywhere e.g. tau in [0,infinity]) and is differentiable everywhere too e.g. is C^infinity. This method to tackle viscoplastic problems is well known and works very well with Fluent too either in 1D or in 2D-3D problems. Have a look to those papers : 1. T.C. Papnastasiou "Flow of materials with yield", Journal of Rheology, 31, 385-404, (1987). 2. E. Mitsoulis, S.S. Abdali, N.C. Markatos, "Flow simulation of Herschel-Bulkley fluids through extrusion dies, Canadian Journal of Chemical Engineering, 71, 147-160, 1993. 3. M. Beaulne, E. Mitsoulis, "Creeping motion of a sphere in tubes filled with Herschel-Bulkley fluids", Journal of Non Newtonian Fluid Mechanics, 72, 55-71, 1997. 4. J. Blackery, E. Mitsoulis, "Creeping motion of a sphere in tubes filled with a Bingham plastic material", Journal of Non Newtonian Fluid Mechanics, 70, 59-77, (1997). 5. I.C. Walton, S.H. Bittleston, "The axial flow of a Bongham plastic in a narrow eccentric annulus", Journal of Fluid Mechanics", 222, 39-60, (1991). With all those informations, I am quite sure you will succeed !! The only remaining thing to do by yourself is to write the UDF for the apparent viscosity (forget about the non-newtonian power law that is not suited to handle yield stress), that is an easy and quick duty. Hope it might help you... Anthony |
April 3, 2013, 11:51 |
lei
hi, Do you know whether liquefied iron ore powder is the viscoplastic fluid\?
I think I should do some steps: 1: do some experiments about the material 2: build the constitutive equation using the UDF |
February 4, 2014, 01:41 |
Satish Gupta
I am also trying to solve a similar problem. where should I attach the udf in fluent because if I attach it to viscosity, I don't find any place to enter the value of power n and consistency index K
September 11, 2018, 17:00 |
Liliana de Luca Xavier Augusto
Hi!
Anyone could validate the UDF of HB fluid? I am simulating a flow between two paralell plates and comparing the results with analytical solution. Although, the results are not in good agreement... Also I had some problemas when initializing the simulation. If I initialize by hybrid initialization and then run the simulation, I got a divergente on first iteration... Then I started the simulation by running a newtonian fluid and than changed to the viscosity calculate by UDF. It converges, but did not match with the analytical solution... Did anyone had the same problem? |
Eulerian Modeling: Frictional Viscosity Help | meangreen | FLUENT | 1 | January 25, 2018 15:13 |
Yielding viscosity for Herschel Bulkley model | Godwin | FLUENT | 1 | December 12, 2011 05:42 |
Power - Law Viscosity Model for Polymers | NickolasPl | OpenFOAM | 2 | August 12, 2011 08:26 |
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation | Pathak | FLOW-3D | 0 | August 24, 2009 06:34 |
kinematic viscosity at diff temperatures,pressures | Mecobio | Main CFD Forum | 0 | November 7, 2005 12:55 |
