October 29, 2001, 21:28 |
Suggestion please
Hi, I am trying to model the flow of particles (DPM) in a fluid. In a given zone of the fluid the particles will be under the effect of a force. So that zone must be well defined.
My question is if there is a better way to do that. I mean, should I define the coordinates of the zone in the UDF? or if there is some kind of griding trick or zone definition I could use to know if the particles are in such zone? (as in the example in the UDF manual about rxion that only occurs in the porous section of the grid). For me the last solution could be better as the solution could be easily generalized to any geometry. Thanks for any suggestion Newbie |
suggestion for thermophysicalproperties for high temperature buoyant flow | braennstroem | OpenFOAM Running, Solving & CFD | 0 | March 21, 2011 14:06 |
Suggestion: Index for abbreviations and glossary | Ralf Schmidt | FLUENT | 0 | September 15, 2005 07:44 |
suggestion need desktop configuration for fluent | Ravinder Reddy | FLUENT | 3 | September 9, 2005 08:09 |
on sliding grid,your suggestion needed | J. H. Van | Main CFD Forum | 3 | July 4, 2002 16:11 |
can you give me some suggestion? | reck | Main CFD Forum | 0 | November 25, 2001 00:40 |
