November 19, 2001, 08:21 |
[TUI & Scheme] Exporting data under Tecplot
Hello, I'm writing a Scheme procedure to export the data files of a directory to the Tecplot format.
I succeed in writing the loop, but i don't know the syntax to export fluent data files in tecplot files. When I use the TUI, I have to use the return key at least one time, and so i can't use the syntax: (ti-menu-load-string (format #f (string-append "/file/export/tecplot " "~/file.plt" ????? I don't know what to write here ?????? ))) Any ideas? Thanks. Mickaël |
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 15:35 |
CGNS vs Tecplot Data Format | LWhitson2 | Main CFD Forum | 3 | July 1, 2011 13:50 |
Exporting data to Tecplot 360 | Genesis | FLUENT | 2 | June 6, 2007 17:53 |
fluent case n data files not exporting to tecplot | krishna | FLUENT | 2 | February 17, 2007 23:24 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
