November 21, 2001, 12:17 |
Question about GAMBIT
Hi, I have imported a IGES file from Pro-E.I have many virtual edges in my geometry.I want to create real faces by using some of theses virtual edges.I converted those virtual edges into reall edges but virtuall edges are "not disappeared" and when I try to make real face with the help of converted real edges,it says that it cannot operate real edges as they are associated with non-reall geometry. Please help me. Thanks Dharmendra
November 21, 2001, 13:46 |
Re: Question about GAMBIT
Hello Dhamendra,
when you import an IGES file into Gambit, you have two options under Translator : Native, and Spatial. If you want real geaometry (edges, faces, vertices), choose Spatial Translator, (and selectNo-Stand alone, vetrtices, edges, faces). Native Translator gives you virtual geometry, and if you want to clean it, you have to delete virtual face, then edges, then vetrices, in order to be left with the real face which was beneath the virtual one you just deleted. This "cleaning" process can be tedious, so it's better to Import initial IGES file using Spatial Translator. Regards, Anna |
November 22, 2001, 03:54 |
Hi Anna, Thank you very much for your suggestion.I tried it successfully. with regards Dharmendra
Gambit maillage question | stage81 | FLUENT | 0 | October 1, 2010 10:06 |
Gambit question. | Pablo Cornejo | FLUENT | 10 | March 10, 2006 09:46 |
Gambit question | LI Y | FLUENT | 2 | April 6, 2003 16:59 |
a question about Gambit | Jack | FLUENT | 5 | February 6, 2003 06:04 |
an easy question about gambit | brian | FLUENT | 3 | December 2, 2002 23:58 |
