December 3, 2001, 23:59 |
contour plot--surface integral
Can anybody help me out in this problem... first the contours of temperature on a blade surface was plotted..the temperature was as expected..then mass-wieghted temperature (surface integral)was calculated on the blade surface..it was ZERO K!...so ,when again temperature contour was plotted again it was ZER0 K! throught on the blade surface....so exit fluent without saving this case and repeat the process all over again but to see the same results..
Regards Theju |
December 5, 2001, 22:55 |
Re: contour plot--surface integral
It's clear because velocity in the wall is zero. For your case, I recommend that you use 'area weighted average'. See the definition of 'mass weighted average' in the manual or fluid dynamics textbook.
Sincerely, Jinwook |
How can I make the axes in a contour plot in tecplot as log scale | seminole | Tecplot | 0 | July 6, 2011 00:20 |
Unable to view contour plot on a plane | azurespirit | ANSYS | 0 | May 23, 2011 08:35 |
Matlab PP: Generating X-vel Contour Error Plot | Bennp2000 | FLUENT | 5 | March 4, 2011 15:58 |
[OpenFOAM] Contour Plot with Paraview | jet | ParaView | 0 | August 26, 2010 10:30 |
Local surface contour line plots | Nandu | FLUENT | 0 | November 9, 2003 23:26 |
