More GAMBIT
Old   January 15, 2002, 03:05
Default More GAMBIT
Christian
Hi.
When meshing with the Coopet tool, the Gambit online manual have an example on how to mesh a combination of a cylinder, a box and a "corner". The operation is divided in 4 steps. Step no.2 is an imprint of the source faces onto each other.
My question is how this imprint is done. Is it done just by selecting the source faces or is there a special command that should be used (if yes: there is this command; I cannot find it).
Thanks
Christian
Old   January 15, 2002, 17:35
Default Re: More GAMBIT
Erwin
Done automatically after you select the source faces
Old   January 16, 2002, 02:54
Christian
Ok. Thank you.
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Does Gambit has a maximum allowable grid number? spartan1516 ANSYS Meshing & Geometry 7 March 25, 2010 09:08
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 10:26
