March 1, 2002, 01:40 |
floating point error
Hi,while running 2D problem with multiphase (air and water)I came across the following error using k-e rng ,vof-implicit model Error: Floating point error: invalid number
Error Object: () i've been getting these errors for so many combinations...plz give me some suggestions.Thanks.Mavinakere. |
March 1, 2002, 05:32 |
Re: floating point error
Try altering the under relaxation factors for whichever residuals are 'blowing up'. Also, if its an unsteady simulation (as it probably should be), try decreasing the time step a little.
March 1, 2002, 16:10 |
i tried altering the underrelaxation factors and then i get convergence detected in AMG solver kinda error.And my problem is with steady state...so no time steps at all.though i want to solve unsteady ,i get errors in the initial level(at say 20-30 iterations)plz give me more parameters to check with.thanks.
March 1, 2002, 17:22 |
A) Use double precision B) Use different mesh size DC
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
