Vertex problem
Old   April 25, 2002, 14:03
Default Vertex problem
Pravir Kumar Rai
I have an existing geometry sent to me by someone. This geometry consist of vertex, edges and faces. On zooming the faces I found that the vertex does not lie on the intersection of the edges.How should I remove this defect?I dont know the corodiante points of intersection so can not move the vertex also.
I am stuck.Please help me.
Old   April 26, 2002, 16:37
Default Re: Vertex problem
Kang
Sometimes display will cause a small shift of vertices - try meshing the faces and see if the mesh would show it as a "defect".
or you could create a vertex by intersection of the two edges - to see if they are the same.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
