Makcro for Velocity-derivatives
Old   April 26, 2002, 05:17
Default Makcro for Velocity-derivatives
Christian
Hi!
I am using Fluent 6.0 an want to access velocity-derivatives within a UDF. The macro in the manual
e.g. C_DWDY(c, t)
seems not to work. Has anybody come across this problem before? I have heard of a problem with these macros before but don"t remember the solution if there was any.
Thanks in advance, Christian
Old   April 26, 2002, 11:34
Default Re: Makcro for Velocity-derivatives
Johnix
I think it can work. I had used it before.
Maybe you can state your problem in details, then ...
It may not work if the case is 2-D (kidding).
Old   April 27, 2002, 02:14
Default Re: Macro for Velocity-derivatives
Christian
Hi!
Nice joke.... I want to use the macro for the computation of a component of the wall stress tensor. The problem is 3d and Fluent computes the derivative, I can see this e.g. in the contour-plot. but the value seems not o be available for my UDF. I have read in tha manual that not all derivatives are accesibble until the solver memory is kept from beeing freed. there is a text command that should prevent this but I don't know how it should be used. But I think it only deals with the C_U_G(c, t) macros. But I need the partial derivative so I cannot work with these. Maybe anybody of you knows a solution,
thanks in advance, Christian
UDM derivatives for - for EHD flow Sandilya Garimella FLUENT 7 September 9, 2013 03:17
Stability Derivatives embolado FLUENT 0 December 27, 2010 01:12
Can we have access temperature derivatives??? behrang2009 Fluent UDF and Scheme Programming 0 July 29, 2010 19:21
UDF - Derivatives for User Defined Memory Variable Sandilya Garimella FLUENT 0 January 14, 2008 10:39
Conversion of cell velocity derivatives Manoj FLUENT 0 November 30, 2005 11:08
