Coolant flow analysis - IC engine
Old   May 17, 2002, 11:11
Default Coolant flow analysis - IC engine
Frank
Hello All, I am trying to run a automotive engine coolant flow analysis. I do not have any real data on the mass flow rate at the inlet. Can any of you out there tell me, an approximate value to use for my flow analysis.. I am guessing it to be around 2Kg/s.
Thanks for your help Frank
Old   May 17, 2002, 13:36
Default Re: Coolant flow analysis - IC engine
Joern
About 2.5kg/s for a 4 cylinder engine should be ok.
Old   May 19, 2002, 15:59
alammar
I would also add that you would need to define your job matrix. It will help narrow your choices! FR will depend not only on the engine size, but on the RPM.
Time domain analysis of Unsteady Flow Nikunj Raghuvanshi FLUENT 2 December 25, 2012 13:09
Steady state vs. mean transient analysis of flow behind a circular cylinder Heini Main CFD Forum 1 June 9, 2011 06:47
Compressible flow analysis Sonu Siemens 3 December 5, 2007 07:25
Muffler flow analysis vatsa Main CFD Forum 0 March 2, 2005 07:53
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
