Problem in solving Conjugate heat transfer
Old   July 22, 2002, 12:56
Default Problem in solving Conjugate heat transfer
Venkata Ramana
Dear users, I have a geomety which consists of fluid & solid continuems I want to create a boundary so that later in fluent I have to specify couple option to solve conjugate condition. I am taking wall as bounday but after importing, couple option is not visible at defining boundary conditions. Thanks in advance Ramana IIT Madras India
Old   July 23, 2002, 01:41
Default Re: Problem in solving Conjugate heat transfer
Ashu
You need to split the volumes to share the common face. Once the face is shared by both the volumes, you can name this particular wall as eg. wall001, the coupled walls will have respective shadow wall as wall001_shadow. You can see which of these is towards solid and fluid in fluid. I don't know why you want to specify the coupled option in fluent when it happens automatically.
Hope this answers your question.
Ashu
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
