December 13, 2002, 17:13 |
Von Karman Vortex
Hello, before I make a model wing to test in my wind tunnel and compare it with CFD results, I want to check out my Turbulence model. I will do this with a simple cilinder. My question is if I should try a time dependant solution because of the von Karman vortex. Are they really important in the surface pressure results? The wind tunnel speed is 30 m/s and the cilinder diameter is 100mm
December 19, 2002, 15:07 |
Re: Von Karman Vortex
Hey! The karman vortex is a laminar effect, taking place at about Re = 100. At Re = 2E5 all the transient effects will be modelled in your tubulence model (quasi-static).
von Karman vortex street. Vortices formation mechanism. | mnvl | Main CFD Forum | 1 | February 24, 2010 17:53 |
Are these reverse von karman vortex street? | quarkz | Main CFD Forum | 1 | August 20, 2009 15:15 |
wmake compiling Problem with OF1.5 | openTom | OpenFOAM Installation | 4 | May 3, 2009 14:44 |
Von karman Vortex street | yoshi | Main CFD Forum | 6 | September 10, 2005 22:09 |
Von Karman Vortex | Rodrigo Madariaga | Main CFD Forum | 0 | December 13, 2002 17:12 |
