mesh quality
Old   January 13, 2003, 11:47
Default mesh quality
sxf
Does anybody have some idea of how to check the mesh quality for Gambit. Thanks in advance.
sxf
Old   January 13, 2003, 12:20
Default Re: mesh quality
Knick
In the very lower-right corner of the Gambit GUI, there is a button named EXAMINE MESS. You may refer to the help files of the Gambit for your special case.
Old   January 13, 2003, 14:10
sxf
Thank, I already know that stuff. I wonder to know how I can judge the mesh quality with it. Thanks again
sxf
Old   January 13, 2003, 21:18
zhhuang
sxf,you can get the geometry information about the mesh using the Quality check tool.And you can fine or coarse it with those information.
Old   January 14, 2003, 10:01
Eric R.
sxf,
Mesh skewness depends on a variety of factors: mesh type, complicated geometries, etc. Typically, you would like to keep both Equiangle and Equisize skewness below 0.75, which can be hard at times. Under no conditions should you have more than 1 or 2 cells in the 0.9 region.
Usually, using the TET/Hybrid (TGRID) meshing scheme leads to high skewness (0.6-0.9) no matter what you do. Using clever decompositioning (breaking volume into more volumes for meshing purposes) to use the Cooper tool is a great way to get higher quality meshes and save on cell size.
Hope this helps. Good luck.
-Eric R.
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
