what is Step AP203?
Old   January 21, 2003, 05:05
Default what is Step AP203?
steven
Hello, can anyone help me? i am using proE to draw and export my drawings to gambit for meshing. but when i tried to import using gambit, it does not work. the display show: Settings-> system->"d-203-is default" ERROR:ACIS error 405:no entities were read.
it also advice to use STEP AP203. what is AP203 and how do i set it?
thanks
Old   January 22, 2003, 10:08
Default Re: what is Step AP203?
Volker Pawlik
AP203 is a special type or step format which normally can be choosed during the CAD-export in th export filter. GAMBIT prefers AP203 form AP203 and AP214.
But let me tell you, that from all formats I red into GAMBIT the step-format caused the most problems. The most frequent error was the same you observed: no entities were found.
Have a look to the export protocol. Normally it already will report, that no entities were exported.
I dont know whether it is true for step but some geometry export formats do export volumes only!
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
