Help Needed: High aspect ratio
Old   January 24, 2003, 03:15
Default Help Needed: High aspect ratio
Michelle
I'm doing a model of rotating disc in enclosed area. The distance between each corotating disc is very small compared to the geometry of the box. However the flow is supposed to be turbulence (with boundary layer). But the current result that I have only the laminar flow present at the gap. Can I use grid adaption to refine the elements? Or is that any other way to tackle this problem? I'm trying to reproduced the shrouded corotating disc effect as in Abrahamson experiment..
High aspect ratio oort OpenFOAM 5 September 16, 2011 14:06
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
Aspect Ratio at high turbulent and swirled flows zago FLUENT 0 May 19, 2004 02:37
