January 29, 2003, 18:24 |
Particle Tracking
I am using discrete phase modeling to simulate my problem. I have a few questions on particle tracking technique.
(1)I read about stochastic tracking and cloud tracking, but could not understand pretty much the details. Please let me know the difference and when are they used ? (2) I have injected 5000 particles in my model. Now if I do stochastic tracking (number of tries =10) then for a single stream id( say stream id 2 and TRACK SINGLE PARTICLE OPTION:ON ) it gives me 10 sets of curved lines going to different places. What does that mean and why are they different? (3) If I change number of tries = 1 then it gives me 1 line, but if I track the same stream id different number of times, it gives me different lines which I cannot understand. (4)Does the information about whether the particle is trapped, escaped, aborted, evaported, has to be gathered from the FLUENT window panel? (5)Does the value of DPM concentrartion taken at wall represent the same thing as the deposition of particles on the wall in terms of Kg/m^3? Thanks Pravir |
January 30, 2003, 10:29 |
Re: Particle Tracking
In answer to question (2), when you set the No of Tries to 10, it means that 10 particle streams are released for each particle ID, each one taking a different path to reflect how turbulence might affect the path of the particle. (random)
Tracking a single particle ID, therefore, will give 10 possible paths for No of Tries = 10. Hope that's clear! J |
January 30, 2003, 19:16 |
Yeah that is clear to me and I was also thinking the same answer but I just wanted to be sure about this. Thanks anyways!!!!
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump | scatman | CFX | 7 | January 8, 2018 00:59 |
massless particle tracking problem | Renold | FLUENT | 0 | January 26, 2011 14:23 |
Particle Tracking for ion | Jun | CFX | 2 | August 31, 2010 08:19 |
Number density tracking rather than particle tracking | Rebecca | Main CFD Forum | 2 | April 23, 2009 12:52 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
