Fluent data structure and geometry
Old   April 21, 2003, 10:18
Default Fluent data structure and geometry
Steven
Hi, All,
Sometimes, I felt myself really by those data types like cell,face,thread,domain,etc when writing UDFs. I do not think Fluent UDF manual gives sufficient information and guide on this topic.
For example, I would like to apply 3 different values for the diffusivity over 3 different zones. I got a kind help for Murali, and I wrote the attached code based on his suggestion. However, this code gives me problem, it cannot go over all the regions and distribute values respectively. It just gave me the same value for all the three zones.
Anyone can help me out? Also, is there any source that I can get some more information on how to conduct the calculation or define properties over zones,faces,cells? The manual looks very simple and not systematic on this.
Thanks in advance.
DEFINE_DIFFUSIVITY(my_diff,c,t,i) {
int zone_id;
Thread *c_thread;
Domain *dom;
real D;
Get_Domain(dom); /*Obtain the zone id of the face*/
for (i=2;i<=4;i++)
if (c_thread==Lookup_Thread(dom,i))
zone_id=i;
switch (zone_id)
case 2:
D=2;
break;
case 3:
D=3;
break;
case 4:
D=4;
break;
return D;
Old   April 21, 2003, 13:43
Default Re: Fluent data structure and geometry
Alex Munoz
Hi
Careful
In fluent you must to use "." for real number example
you write D=3;
you must write D=3.0; or D=3.;
The other problems you must to write several examples to understand how to write a good UDF
Best regards
Alex
Old   April 22, 2003, 11:25
Steven
Thanks, Alex. I just wanted to give a simple example, but made a mistake there. Actually, I have some experience with Fluent UDF, but I think the manual does not give sufficient guide in applying different properties or math equations to different regions. Any hint on this. Thank you.
Steven
Mapping of plot3d data to OpenFOAM case Fransje OpenFOAM 2 January 23, 2014 00:13
Generic case structure for iterative design process capucsc OpenFOAM 4 May 6, 2011 11:26
structured and unstructured grids user Main CFD Forum 6 November 25, 2010 01:14
Modelling deforming inflatable geometry in Fluent Mark FLUENT 2 October 4, 2006 05:36
Fluent for turbulence modeling Sujit FLUENT 2 August 18, 2003 17:17
