a laminar circular-tube heat transfer problem
Old   April 28, 2003, 05:55
Default a laminar circular-tube heat transfer problem
majestywzh
i want to simulate the two-phase laminar flow and heat transfer in the circular tube,and i firstly test the mesh and fluent calculating ability by using single phase(water).I have written udf of the inlet velocity for the laminar flow(that is U=2Um*(1-(r/R)^2)),and the final result of pressure drop is exactly in agreement with the theory.
But the problem is that the heat transfer Nu deviates from the theoretical value( Nu=4.366 for Constant Flux ,and Nu=3.67 for constant wall temperature,remember?)(by the way,i also have written udf for the inlet temperature ,and i surely got a fully-developed flow)?
what may be the reasons?any advices are much appreciated!
Old   April 28, 2003, 05:59
Default Re: a laminar circular-tube heat transfer problem
majestywzh
is it possible that Fluent does not solve the energy equation exactly?
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
transient heat transfer problem kamal FLUENT 2 June 29, 2008 14:55
Heat Transfer problem (two different fluids) Jon FLUENT 5 February 20, 2008 06:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
conjugate heat transfer problem Andreas Siemens 0 February 5, 2002 08:00
