Exceed-Gambit problem
Old   May 16, 2003, 09:53
Default Exceed-Gambit problem
Basil
Hi, everybody.
I'm not a big expert in Exceed. I got Gambit 2.0.4.and already have Exceed 8.0 and 3D. Can somebody help me with the step by step instructions how to make it running under W2000.
I just start Exceed and when I'm trying to run Gambit.exe from Fluent.Inc/ntbin/ntx86/ it gives me "Unable to find Exceed X server"
I need help in how correctly set up X Window server for Gambit.
Old   May 17, 2003, 10:03
Default Re: Exceed-Gambit problem
James Date
Have you tried calling up your supplier for support information!!!
EXCEED version 8.0 is NOT supported at this time and GAMBIT and FIDAP will not run with this version. You need Exceed 7.1.
Check out the Fluent web site, there is a section on this problem.
http://www.fluent.com/support/instal...aq/xserver.htm
Regards James
Old   May 23, 2003, 15:54
Johnix
It's an old problem ... hoho...
Actually, I've done a patch for it long time ago. And in fact, Gambit can run on 95/98/NT/2K/XP with exceed 6/7/8. So, if you want you can send me a sincere message, and I can arrange the patch for you.
===THERE IS A WHEEL, THERE IS A WAY===
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
tips for runing Gambit without Exceed in Win Vista Fabio Saltara FLUENT 9 September 23, 2011 13:59
Gambit error: Cannot find exceed x server Jake FLUENT 6 September 10, 2011 11:43
Gambit 6.3 problems with Exceed Anonymous FLUENT 1 June 15, 2006 02:23
exceed for gambit 2.2 steve FLUENT 4 July 26, 2005 09:09
