Fluent & Gambit Help
Old   June 7, 2003, 15:13
Default Fluent & Gambit Help
Johnny B
Looking for an easy read, straightforward intto guide to fluent and gambit. Any thoughts?
Old   June 7, 2003, 16:38
Default Re: Fluent & Gambit Help
Murali
manuals.
Murali
Old   June 8, 2003, 06:46
mateus
Hi!
I think the best way to start is to do go trough tutorials...
You can find documentation on:
http://vayu.engr.twsu.edu/fluent/
http://www.udel.edu/topics/software/...docs/index.htm
Regards
MATEUS
Old   June 9, 2003, 03:32
zxaar
i think the best way to start and learn is
TO USE GAMBIT AND FLUENT DIRECTLY, EVERYTHING IS IN LOGICAL ORDER, (GEOMETRY : POINT,VERTEX, SURFACES,VOLUMES MESHING : EDGES,FACES,VOLUMES AND BC)
yaa u can look into tuts,for simple conusltancy. gambit takes 2 days ..fluent 1 enough.
Old   June 9, 2003, 04:43
mateus
Hi!
I just want to say that don't think that you will know a lot about CFD after 3 days of using Fluent. Yes, you will be able to get a solution, but you won't have any idea if the solution is right, you won't know how did you get the solution, you won't know anything.
Learning cfd is a loooooooooooong process, which requires a lot of theory and expirience....
Regards
MATEUS
Old   June 9, 2003, 05:01
ff
And after 2 days you will be CFD expert!!!!
Old   June 9, 2003, 07:44
zxaar
well i told u how to start ..i din't mention that stop after that .... why i said so is, i have seen lot of people starting to learn this subject with tuts or manuals ..they just keep reading it (1000s of pages for months) ..i feel softies like gambit ..the more u spend time with them more u learn ...
this a practical thing ..as at my place ..we were two guys asked to learn gambit and fluent to learn ...he is still learning ..i have done few projects ..thats the diff.
[GAMBIT] BC's value assignment in Gambit Vs. Fluent (solver) hadikhayyamian ANSYS Meshing & Geometry 5 December 21, 2010 12:28
Global c.sys in GAMBIT or FLUENT Kasper Skriver FLUENT 4 November 10, 2010 12:49
Gambit Fluent export John Go FLUENT 0 March 7, 2009 14:48
Fluent case file into Gambit Eric R. FLUENT 7 July 17, 2002 14:11
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 12:35
