turbulent intensity.
Old   June 9, 2003, 20:10
Default turbulent intensity.
liuyan
Hello everyone, I am simulating the 3D flow field in the compressor, Re=650000, how can I set the turbulent intensity of the inlet boundary conditions. Now, I give the value 3, but I don¡¯t know whether it is desirable. Thank you.
Old   June 10, 2003, 12:53
Default Re: turbulent intensity.
Alex Munoz
Hi
Fluent user manual have a section about turbulent intensity, In my opinion this information is suficient to solve your question. However, you have to find the information for yourself.
6.2.2 Determing Turbulent parameters Turbulent Intesity (subsection)
Best Regards
Alex Munoz
Old   June 12, 2003, 03:53
liuyan
Thank you. I will try to do that again.
Old   June 15, 2003, 04:40
Rahul
see boundary conditions chapter in fluent manual. there you will find the definitions and formula for calculating turbulence intensity for core flow through pipes.
How to calculate Turbulent Intensity? prem FLUENT 10 September 29, 2018 09:46
k-epsilon: Defining turbulent intensity and length scale? klausb OpenFOAM 0 January 23, 2011 07:28
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 10:36
Turbulent intensity swe704 Main CFD Forum 0 November 13, 2009 03:42
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
