Accumulation at boundary with TRAP condition
Old   June 30, 2003, 10:49
Default Accumulation at boundary with TRAP condition
Umesh Shah
Hello all,
I have a surface with boudary condition 'TRAP'. On that surface particle comes and get disapear from the calculation.
Now in real process for which i m trying to make this model, particles get accumulated on that surface with time.
So the question is,
How can I get accumulation rate of particles on that surface which has such boundary condition?
I am using FLUENT 6, DPM . for information.
I hope what i hv written is clear to understand.
Umesh
Old   June 30, 2003, 16:37
Default Re: Accumulation at boundary with TRAP condition
Alex Munoz
Hi
I think you can write a file using report>Discrete Phse>Sample
Then you select the boundary conditions that you want to track the particles. Of course, you have to write a UDF (DPM_OUTPUT) if you don't want the default output file, which reports the following variables (positions (x,y,z) velocities(u,v,w), particle diameter, temperature, mass-flow, particle-time, injection ID)
Once you heva get your file you can manipulate the data to generate an accumulation rate.
Best regards
Alex Munoz
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
