surface reaction rate plot at diffusiion limit cas |
August 21, 2003, 15:20 |
I have a diffusion-limited case for surface reaction. So the reactant at surface is almost zero, and reaction rate is limited by the diffusion from bulk face, which is achieved by using a high pre-exponent factor value (1e15). The simulation shows that the gas products formed at solid surface diffused back into gas phase by plotting the contour of species, but when plotting x-y reaction rate on the surface, the rate is zero, any comments?
Thanks |
August 22, 2003, 04:54 |
Re: surface reaction rate plot at diffusiion limit
Have you tried looking at countours and/or ticking the node option?? I mean contours of the surface.
It may be a bug. The reaction rate will have to be non-zero. Greg |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
problem about porous media and surface reaction | Jeff Lee | FLUENT | 3 | November 24, 2011 13:46 |
Can Flow-3D plot the free surface area in Iso-surface or colour variable? | therockyy | FLOW-3D | 1 | June 20, 2010 19:36 |
Surface reaction rate | Jon | FLUENT | 5 | December 19, 2007 07:01 |
Reaction Rate | Dhruv | Siemens | 1 | October 1, 2005 10:34 |
