Dynamic Meshing
Old   September 15, 2003, 17:31
Default Dynamic Meshing
Max
I am trying to write a dynamic mesh UDF. I've referred to Chapter 5 "Dynamic Mesh Macros for UDF" of the Dynamic Mesh Manual for help. The example can also be found in 4.5.3 of the Fluent manual. When compiling the cantilever beam example UDF, which uses the "define_grid_motion" UDF, I get a compiling error: "structure reference not implemented". I would assume that the example in the manual should not have any errors in it and would compile. Any help is greatly appreciated!
Old   September 20, 2003, 14:13
Default Re: Dynamic Meshing
Pat
I ran into a lot of problems when trying to use the UDF guide for dynamic meshing. I finally got my runs to work by simply calculating the location of each node point (x,y) and then directly redefining the location.
To move a node to (3,2) I used: NODE_X (v) = 3.0 NODE_Y (v) = 2.0
where v = F_NODE (f, tf, n);
-Pat
Dynamic meshing Manoj Kumar FLUENT 3 June 27, 2010 19:26
Dynamic Meshing with Flow 3D M_Agni FLOW-3D 1 June 13, 2010 18:20
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
help for dynamic meshing for incylinder combustion Ramesh K FLUENT 0 June 19, 2006 06:29
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 02:55
