October 15, 2003, 18:19 |
Left Handed faces
After creating grid interfaces and grid checking in my domain I found left handed faces. Is it possible to correct this problem? Thanks in advice. ff |
October 16, 2003, 05:02 |
Re: Left Handed faces
Try this: type in the command window:
/grid/modify-zones/repair-face-handedness |
October 16, 2003, 05:58 |
Thanks Erwin. I already used that function but after as well as before I have left handed faces in my domain (without negative volumes). MY final mesh was build using two separate meshes which are merged with fluent utillity tools. Those separate meshes are valid without left handed faces and without negative volumes. After creating grid interafecs left handed faces apears but as I say without negative voluems. Any tips?
Thanks in advice, ff |
October 16, 2003, 11:10 |
type at the FLUENT console:
(rpsetvar 'nonconformal/cell-faces 0) before creating the grid interface. Make sure that you type the paranthesis as well. enjoy! |
October 17, 2003, 09:34 |
Thanks,
I'll try. Where I can find more about rpsetvar functions. Thanks, ff |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
how to treat left handed faces | xiang | FLUENT | 1 | March 10, 2003 07:08 |
