conjugate heat transfer
Old   October 17, 2003, 02:44
Default conjugate heat transfer
ajay chandra
How to model a plate heated from bottom and upper surface open to air flow, a conduction-convection combined problem? even giving two zone in gambit the solver accepts only one zone problem.
Old   October 21, 2003, 17:07
Default Re: conjugate heat transfer
Prabu Parthasarathy
Hi Ajay,
Could you explain your problem in more detail? It seems to me that your problem is fairly simple.
Prabu
Old   October 26, 2003, 01:27
ajay chandra
Hellow prbhu Happy diwali Of course the problem is quite simple, lower surface of a plate is heated, which is kept in a insulated duct having air flow over upper surface of plate.from lower surface to upper surface of plate heat flow through conduction and from opper surface of plate to air, heat flow through convection is to be simulated. Ajay
Old   October 26, 2010, 17:14
kirankarki is on a distinguished road
Hi Ajay,
Did you get your case works? If so, please would you share how you did it?
Thanks a lot
kirankarki is offline   Reply With Quote
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 15:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
