Turbulence Intensity
Old   November 12, 2003, 06:01
Default Turbulence Intensity
Tom
How do I calculate the turbulence intensity at the inlet of my pipe section to apply as a boundary condition. The pipe is 203mm in diameter and I know the reynolds number is 8.58e+06. Do I need to know any other information to calculate this?
Old   November 12, 2003, 06:50
Default Re: Turbulence Intensity
eric
You can used the following
I = 0.16*Re^-1/8
Also see 6.2.2 in the Fluent manual
Eric
Old   November 12, 2003, 06:55
prasanth
Dear Eric, Then what will be the Intesity for natural convection, where Rayleigh number is criteria.
Old   November 14, 2003, 07:07
B. David
eric, can u name the reference for this correlation, n if u know the correlation for turbulent dissipiation rate.plz let me know. thanks for this information. david
Old   November 14, 2003, 09:53
eric
I'm sorry have no experience with natural convection problems so i can't tell you anything about the turbulence intensity.
I just referred to the fluent manual 6.2.2 for this intensity formula.
Regards
Eric
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
