"CAVITATION" Special Pressure-Corr relaxation!!!
Old   November 17, 2003, 02:42
Default "CAVITATION" Special Pressure-Corr relaxation!!!
ROOZBEH
Hi; I want to model cloud cavitation arround a simple hydrofoil with Fluent. I work with version 6.1.22 of this software recently. In its documentation there is some guidlines suggested to obtain a converged solution. I begin the solution with a non-cavitating condition and approach slowly to the operating condition. At a non-cavitating condition, when I solve only the flow equations, I obtain a stable converged solution; But in the same condition(non-cavitating i.e. a low velocity or a high pressure) when I add volume fraction equation of cavitation to equations, I do not have a converged stable solution.(the main problem is the "continuity" residue.) Of course this is by defult setting of "pressure limit" or"Termination criteria" or ... Because fluent documentation suggestion, when I type: (rpsetvar,'pressure-correction/relax value) I recieved error: "invalid command[rpsetvar]" Can I set this relaxation in solution pannel? Where I should type this correctly? Thanks.
Old   November 17, 2003, 06:29
Default Re: "CAVITATION" Special Pressure-Corr relaxation!
cfd
That's a mistake: the "," behind "rpsetvar" has to be omitted. Try (rpsetvar 'pressure-correction/relax 0.4) That should work.
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 07:26
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 21:18
Operating condition in Fluent MASOUD FLUENT 3 September 16, 2010 17:50
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
