injection in Combustion problem
Old   November 18, 2003, 01:43
Default injection in Combustion problem
CCS
I am working on combustion of Diesel Oil. There is a cylindrical(560mm dia.) combustor. At inlet of combustor there is a spray of LDO(Light Diesel Oil) from nozzle of 0.8 mm dia with air inlet from blower.
For analysis, can I take "Injection" of single 0.8mm for the combustion problem?? I have not define any fuel inlet face. just air inlet face has been created in the grid. is it ok?? Then How to start combustion??
Thanks
CCS
Old   November 21, 2003, 07:13
Default Re: injection in Combustion problem
Tom
You can set up your injection using the DPM approach. You can specify where you want the injection to take place, either from a surface or a point injection. TO start combustion you need to patch an area of the flow to initiate combustion. You do this after you have initialized the solution. Pacth a temperature around 2000 K and you should be ok.
Dont forget to follow the combustion laws and set the correct parameters in the materials pannel.
Old   November 21, 2003, 09:20
CCS
Thanks a lot, I will check it
combustion chamber problem mcnair ANSYS Meshing & Geometry 0 March 16, 2011 12:41
Biomass Pellet Combustion - problem with CO nmanic FLUENT 0 December 15, 2010 18:00
patch injection problem, a possible bug? jsltlx OpenFOAM Bugs 4 April 20, 2010 09:42
KIVA3V2R injection problem Jeffery Main CFD Forum 0 April 21, 2006 17:21
Combustion Problem chetan shah FLUENT 1 October 17, 2003 12:20
