solid-solid interaction
Old   December 17, 2003, 01:03
Default solid-solid interaction
krishna
hai, In my problem, in a cylindrical combustor, coal comes from an inlet port horizoantally. In the combustor, sand is patched to a height and air is sent from bottom of combustor. Now, I want to know that, is there any specific laws for drag etc. for the solid-solid interaction(sand-coal). Can we use existing laws in Fluent.?IF so, which one?
Awaiting for a response, Thanking you krishna
Old   December 17, 2003, 09:24
Default Re: solid-solid interaction
ap
FLUENT implements the Syamlal-O'Brian symmetric drag function for pairs of solid phases.
You can select it in the Phase->Interaction->Drag panel.
Hi
ap
Old   December 24, 2003, 04:04
krishna
Thanks once again ap, if the same problem is considered with energy equation included, such that the fluid is given a inlet Temperature, what model can we use for fluid-solid ineraction and also solid-solid interaction.
Thanking You,
krishna.
Chemical interaction between solid and fluid rock FLUENT 3 March 31, 2010 17:49
Liquid solid interaction and GUI question danvica OpenFOAM Pre-Processing 0 December 6, 2007 04:34
flotran fluid solid interaction Rishab Mahajan Main CFD Forum 0 December 24, 2005 00:26
Fluid Solid Interaction - divergence bebes CFX 1 May 5, 2005 18:46
