[HELP] porous media in cylindrical channel
Old   January 5, 2004, 18:31
Default [HELP] porous media in cylindrical channel
swanshin
Hi! I'm trying to model cylindrical channel with porous medium inside. I'm having problem with deciding directional vector. Because I'm doing 2D simulation, there is only one direction vector I have to specify. It gives quite different result from (1,0) and (0,1) direction. Is there any other way to specify conical direction in 2D? or Is the some way to use cylindrical coordinate system in Fluent?
Thanks in advance
Old   January 5, 2004, 21:21
Default Re: [HELP] porous media in cylindrical channel
MN
You can set up a 2d axisymmetric problem in FLUENT by creating a 2D mesh, with the axis of symmetric/center line on the x-axis, then making sure that within FLUENT, you specify the 2d axisymmetric model. Once you do this, the default setting for the porous zone direction ( (1,0) I believe) ) should work.
Old   January 6, 2004, 11:08
swanshin
Thanks for replying. But my probelm is NOT axisymmetric problem. The coordinate I want to solve is NOT (r,z) coordinate BUT (r, theta) coordiante. Is there any way I can do this? or is there any way to specify porous directional vector in theta direction?
Thanks again
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 09:43
Porous Media in Cylindrical Geometry Danny B FLUENT 3 September 12, 2008 19:23
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
