January 20, 2004, 12:03 |
wall in fluids flow.
Has anyone tried anything like this, if so, will it work and are there any tips.
I wish to create two flows, seperated by a wall. However, I also the flow field to be solved as if the wall was not there, so I am planning on setting the absolute components of momentum to be the x,y and z velocities from the flow on the other side. There is a reason I wish to attempt this. Any comments or suggestions would be apprectiated |
January 20, 2004, 13:46 |
Re: wall in fluids flow.
make your wall by splitting your volume by a face or by cutting your face by an edge. when you export your mesh from GAmbit to fluent you will get a wall and wall shadow. when you want to solve your problem without the wall, just convert your wall into interior.
co2 |
January 21, 2004, 04:25 |
Thankyou for your comments, but I need to solve the simuliation without the wall is unimportant to my study, I need for the wall to exist, but not the flow field to react as if it did not, in the same calculation.
January 23, 2004, 02:13 |
What is the purpose of the wall in your calculation. What will you use it for? If you are trying to avoid viscous effects you can use symmetry bc instead of wall. In this case wall does not cause any momentum loss but it directs the flow so as to derivatives of all flow variables normal to the wall are zero. If your aim is to use the wall as a postprocess surface you can make it interior. If you can explain, clearly, what your aim is, may be we can suggest a few things.
Regards, gelisli |
Turbulent cyclic pipe flow, wall functions and y+ | clyde | OpenFOAM Running, Solving & CFD | 3 | March 17, 2014 06:08 |
Velocity at wall in an internal flow | rsmartins | CFX | 3 | July 16, 2011 06:58 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Wall Reaction in Turbulent flow | Rajab | FLUENT | 1 | June 27, 2002 20:34 |
